Max effort 346
Old Nov 27, 2005 | 09:44 AM
sickss228's Avatar
Default Max effort 346
Hey guys after blowing up my motor I have decided to build a max effort stock cube motor to race in some events, but still be streetable. I just wanted to see what some of you think about a good rotating assembly and valvetrain I should use, also any tricks or tips that can be done to extract that last ounce of power. I am going with Cartek's 3x LS6 heads and cam, since I still have these from my old motor. I also just ordered the FAST 90mm (which will be port matched to the heads) and Nick Williams TB and have SVO 30lb/hr injectors with a racetronix plug n play pump. Any help or suggestions would be greatly appreciated. Thanks
Old Nov 27, 2005 | 12:50 PM
Steve Burger's Avatar
LS1TECH Sponsor
Heads, Cam and Compression are what will make HP. So for you it will be compression as the other 2 are fixed. I am looking at the same thisn myself. Availability of race fuel will determine what I do.
Old Nov 27, 2005 | 12:57 PM
PREDATOR-Z's Avatar
Nitrated polished stock crank, 6.125 lunati rods and Wiseco/Diamond pistons.
Most importantly a shop that knows their LSx stuff.
