Cleaning heads
Old Nov 29, 2005 | 08:11 PM
Bimmer Tech's Avatar
Default Cleaning heads
I am currently reuilding an engine and doing the usual seals and gaskets. Questions is how do I clean the crbon buildup in the combustion chamber and ports? I am disassembling the head to do the valve seals, so I can soak the head in something to clean it up. Soak it in what? I went looking for an automotive solvent, but couldn't find anything at the parts store. Any suggetions?
Old Nov 29, 2005 | 08:39 PM
TAQuickness's Avatar
scotch brite pads, mineral spirits or wd40, and a strong solvent like MEK. Don't forget rubber gloves and a hard brisle tooth brush helps too
Old Nov 29, 2005 | 08:44 PM
Xtnct00WS6's Avatar
Which sponsor did you get the Flux Capacitor from TAQuickness?
I want 1.8 jiggawatts too!!!
Old Nov 29, 2005 | 09:32 PM
Where do I get the strong solvent from? Will soaking in mineral spirits alone work?
Old Nov 29, 2005 | 11:15 PM
no, you will need some elbow grease. you get get solvents in the paint section at Home Depot
Old Nov 29, 2005 | 11:16 PM
HPE ---->
