whats the biggest intake valve ,
The more air you can flow on the smallest valves/runners will always net more power because the air velocity will be very high. As I stated in another post...more air doesn't necessarily mean more power, but how fast you can move the air is what really matters.
Example:
1. 225cc runners with 2.055 intake valve flowing 315 cfm
vs.
2. 215cc runners with 2.02 intake valve flowing 300 cfm
Option 2 will beat out option 1 on a same setup strictly because the flow velocities will be much higher then option 1, even though it flows slightly less air.
Make sense?
Regards,
Adrian
2.040 are about the biggest you can use with stock seats.
