Comp Hex adjust question.
Old Nov 30, 2005 | 10:34 PM
John02SS's Avatar
Default Comp Hex adjust question.
Putting a cam in and the car has a comp hex adjust on it. I've never installed one and the crank sprocket has no marks on it to line up. The dot is on the cam sprocket, but nothing on the crank sprocket. Also, what is the settings for the hex adjust set? I can't seem to find any directions on what the marks represent.
John
Old Dec 1, 2005 | 12:25 AM
ArcticZ28's Avatar
This link should help you:
http://www.compcams.com/Technical/In.../Files/175.pdf
If not, try these:
http://www.compcams.com/Technical/In.../Files/173.pdf
http://www.compcams.com/Technical/In.../Files/161.pdf
Old Dec 1, 2005 | 01:08 AM
John02SS's Avatar
Thanks man! It was getting late and the comp site wasn't cooperating with me! The crank has no alignment marks on it though. I'll pull the oil pump off and double check it.
John
Old Dec 1, 2005 | 01:47 AM
ArcticZ28's Avatar
That'd be a good idea to play it safe
