cam question
Old Dec 1, 2005 | 01:02 PM
seadoo's Avatar
Default cam question
is there a way that i can send the cam out to have it checked by the company to make sure that everything is good with it.?
btw: its a 226/230/113 cartech stage 2 by comp cams
thanks.
Old Dec 1, 2005 | 01:05 PM
radkon's Avatar
I don't know if you are looking for damage done to the cam or what but anyone with a camdoctor setup can check the specs.
Old Dec 2, 2005 | 01:59 AM
spec_j's Avatar
i called around local, and all but one of the 5 places i called even knew what it was, i will see if i can talk to Comp tomorrow and see what they say
Old Dec 2, 2005 | 03:34 AM
tbojbob's Avatar
Thunder Racing can run Cam Pro Plus on it, that will tell you ALL the specs on the cam. They charge a nominal fee for this fine service!
Old Dec 16, 2005 | 02:36 AM
spec_j's Avatar
thanks bro
