Retorquing head studs
Subscribe
Dec 6, 2005 | 10:17 PM
I installed the heads and everything the other day on my motor, and I wanted to make sure, before I went to far that I didnt need to wait a little bit, and retorque all the head stud nuts. I did them in 3 passes, approx. 37.5 then about 55, then 70. After i got done, i checked all of them, and they were all at 70. I was just wondering if I needed to retorque them after it had been a few days, or after I let the engine go through a few heat cycles. Any help is appreciated. Thanks.
Reply 0
Dec 6, 2005 | 11:06 PM
You did well by taking them down in steps.
No need to re-torque head bolts.
Reply 0
Dec 7, 2005 | 06:25 AM
These are the studs though. I thought there was one re-torque on them required after a heat cycle, but honestly am not sure. With ARP, I always check with their tech support, which is excellent by the way.
Reply 0
Dec 7, 2005 | 06:33 AM
Although many (most?) people don't retorque them after being heat cycled, I would recommend it.
Reply 0
Dec 7, 2005 | 07:25 AM
let them rest over night then check again.
Reply 0
Dec 7, 2005 | 08:02 AM
Thanks for the info. I'll check the outter ones, and see if any of them move, so i dont have to take off the rockers again. I appreciate the input.
Reply 0
Dec 7, 2005 | 09:43 AM
Quote: let them rest over night then check again.
absolutely correct!
Reply 0
Dec 7, 2005 | 11:04 AM
Would this apply to MLS gaskets as well?
Reply 0
Dec 7, 2005 | 02:04 PM
Gaskets dont matter...its the studs that do....experts recommend after a heat cycle also if you can...i didnt
Reply 0
Dec 7, 2005 | 03:56 PM
That's really interesting. I guess you can't knock an extra ounce of prevention,
but a new set of bolts stretch to clamp down on the head.
I've never heard of taking a crated motor, or rebuilding a strip motor then
checking torque after a few passes.
Torquing in steps however is a fairly standard practice, and is proper.
In any case, treat your engine as it were your life.
Reply 0
Dec 7, 2005 | 05:32 PM
Since I already had the rockers on, I just checked the ones on the outside of the head, and all of them were still at 70 lbs.
Reply 0
Subscribe
