Cam questions
1) I have stock heads and probably will for a while.
2) Stock manifolds
I know...with 3 in. Ypipe 3) Stock intake, for now
Can I use a g5x3 with the stock heads, intake, manifolds? the x2 is rated at 232/240 .595/.609 112 or 114+4 and the x3 specs are unlisted but said to be bigger so will they work with the stock heads?
I know the intake and manifolds need to be upgraded to see the max potential of the cam but will I be alright if I don't get them right away?
Please suggest any other cams I might like, Ive been researching the **** out of cams but figured I might as well post another cam thread.
Btw...I am running an A3 with a vig.3200 and the stock 3.23's
346 n.a. 100 dry shot next year
No trans brake
I want power too not just the lope. I know there are stealthy cams and not so stealthy cams so i was just narrowing it down to what I want. Ive read about the g5x3 being used with stock heads by a couple members and I was just seeing if it is something that others would do before I waste my money.
