Bigger valves in stock head
If you open the bowls and seats up to about 90% of the larger valve diameter then you get much more flow. Just putting in the larger valves normally increases very low-lift flow only at the sacrifice of a significant amount of high-lift flow.
Some people can get 300+ CFM from a stock head with the bigger valves when the port is reworked.
