why is the vally "block off plate" so thick?
Old Dec 13, 2005 | 12:29 PM
treyZ28's Avatar
Default why is the vally "block off plate" so thick?
the LS1 has a dead vally- but i noticed my the plate was REALLY thick. What gives? you would think a thin peice of of stamped steel would do the trick.
Supplier planning to pull a cost savings rabbit out of the hat?
Old Dec 13, 2005 | 01:08 PM
jub jub's Avatar
I would imagine it's thick because it's where the knock sensors are located.
Old Dec 13, 2005 | 01:45 PM
c5dream's Avatar
Yeah I'd say the same thing because of knock sensors.
Old Dec 13, 2005 | 01:51 PM
Cop Car's Avatar
im sure it also adds rigidity to the block (think about the aftermarket girdles for sale) unlike first gen SBCs as you know the intake isnt a structural part of the motor in Gen IIIs thats my guess
Old Dec 13, 2005 | 04:40 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
this is what I was already assuming as well. Anyone else know?
Old Dec 13, 2005 | 09:56 PM
01ArcticSS's Avatar
Metal distorts with heat, and I believe it is worse when it is exposed to heat cycling (hot then cold, then hot...) - a thin piece would warp fairly quickly and you would be letting all kinds of nasties into the valley....
Old Dec 14, 2005 | 12:25 AM
treyZ28's Avatar
wouldn't they use steel then? why aluminum? its more expensive and weaker
Old Dec 14, 2005 | 12:56 AM
CAT3's Avatar
Restricted User
Using steel and aluminum creates its own issues, differences in expansion with heat. just my two!
Old Dec 14, 2005 | 11:02 AM
treyZ28's Avatar
but aluminum expands MORE than steel. much more .
