ARP Main Studs... Torque to Yield, or Torque to Spec?
Old Dec 18, 2005 | 02:05 PM
Ferocity02's Avatar
Question ARP Main Studs... Torque to Yield, or Torque to Spec?
I am trying to figure out the proper way to torque the ARP main studs. I have read about people who use 15 lb-ft + 80 degress on the inside bolts, 15 lb-ft + 53 degrees on the outside bolts, and then someone said they are 60 lb-ft on the inners and 50 lb-ft on the outers. I don't have instructions for mine, so does anyone know? I figure it would be different than the stock TTY specs.
Old Dec 18, 2005 | 03:39 PM
racecar's Avatar
The recommended torque from ARP is 60 lb with Moly lube for ALL main cap studs. Forget about that 80 degree stuff. I have had my motor apart several times and 60 w/moly seems to work great. The outside block bolts are the stock GM bolts that are 18 lbs, they have some kind of a sealer/loctite under the head. When checking main bearing clearances, torque all, including the outside 18 lb, it makes a difference.
Old Dec 18, 2005 | 03:44 PM
V8_DSM_V8again's Avatar
Here
The main caps are torqued down to 60 ft-lb on the inside and 50 ft-lb on the outside.
http://www.highperformancepontiac.co..._ls1_455build/
Long stud less tq...
Old Dec 18, 2005 | 06:29 PM
Ferocity02's Avatar
Originally Posted by V8_DSM_V8again
Those looks like thee same bolts/studs I have, thanks for the link!
Old Dec 18, 2005 | 07:07 PM
Its the same ARP kit.
ARP is redoing their website so I could'nt find their install guide.. Which was normally avail online.
