Help with preload and Yella Terra Rockers
When I bolt up the rocker on #1 at TDC and check the preload I get about 2+ turns. Their instructions say to add shims to decrease the turns. Yet, it takes 3 shims to even get close.
So, would you say my pushrods are too short?
My preload is about 1 1/4 turns before 22 ft lbs. What change in pushrod length would I need to change the preload to < 1 1/4 turns? Longer or shorter than my 7.4"?
I beleive your 1 1/4 turns is still reasonable but wouldn't recommend more than that.
