Valvetrain Noise!! Help
Old Dec 23, 2005 | 01:49 PM
dalejr8ls1's Avatar
Default Valvetrain Noise!! Help
I just pulled my heads on my ls1 to drill and tap new header threads and i have just started it and it runs and idles fine but i have a valvetrain noise, a knocking sound. what could that be?? I installed everything in order as it was and cant think of what it is. Or does it make noise for the first while after starting? when i started it, i made the noise only on one side, but it got worse and is now on both sides after about 5 min of running. Any suggestions will help.
Thanks
Old Dec 23, 2005 | 02:00 PM
vettenuts's Avatar
How is the oil pressure? I know when I did my Crane rocker installation, it was noisy for about 5 minutes and then settled down.
Did everything go back in the same place?
Maybe you should pull a cover and verify your rockers are still tight.
Old Dec 23, 2005 | 11:37 PM
87Fake's Avatar
Deffinately check the rockers. I'd suspect that first.
Old Dec 24, 2005 | 12:16 AM
aux_fast_cam's Avatar
make sure a header is not leaking, some people have mistaken that for valvetrain noise
