rocker arm problem help!!
i am in then middle of a H/C swap i am putting the valve covers back on and the rocker arms are hitting the valve cover. they are yella terra rocker arms. the cam is a 226/236 is that matters. please let me know what may be wrong with it. i am in need of any help i can get right now.
Look for the wear marks on the underside of the covers. The rockers may be hitting those thin aluminum baffle plates. They are riveted in. You can grind the rivet heads off and remove the baffles. That should give you the clearance you need.
