JPR tool
Old Dec 27, 2005 | 01:21 PM
FBGSU02's Avatar
Default JPR tool
does anyone have the JPR tool that is used to hold lifters up during a cam install that i can buy thanks frankie
Old Dec 27, 2005 | 01:32 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
You can make your own using thin rods from Home Depot. Use search for the correct diameter size- I always forget.
I believe Thunder sells the actual JPR rods.
Old Dec 27, 2005 | 02:08 PM
11 Bravo's Avatar
Shame on you for typing the initials JPR lol
freakynipples69's Avatar
save money and search on how to make your own, its really simple to do and works amazing.
Old Dec 27, 2005 | 03:07 PM
TA TECH's Avatar
5/16 wood dowels from home depot few dollars just sharpen the end like a pencil and cut it 4inches longer than the cam!Hope this helps!
Old Dec 27, 2005 | 03:11 PM
GM Muscle's Avatar
Make your own. My bound up in the motor and it was a huge pain in the ***, I had to file them down to get them to work right. From what I've heard, it's happened to other people too.
Old Dec 27, 2005 | 03:36 PM
snake charmer's Avatar
i used 3/16 metal dowels from the depot, just cut them a little over the length of the cam and marked a line to know it would be in all the way.
Old Dec 27, 2005 | 09:17 PM
Zeus's Avatar
3/16's is too small. People tried that before and had a lifter slide past. 5/16's is the smallest you can go and still be safe. I tried to use metal rods like the JRP tool, and even after extensive grinding the passenger's side still didn't slide in. It was really bound up good. Tried the wooden dowels and it went in easy as pie.
I've heard wood is the best because the holes aren't in a straight line, but I was REALLY scared the wood might break off inside the engine. What a bitch that would be to get out.
Old Dec 27, 2005 | 09:58 PM
hellbents10's Avatar
LS1Tech Sponsor
Just spin the cam and pull it out...slide the new one in, lol.
Old Dec 27, 2005 | 09:59 PM
!LS1 11 Second Club
And cross your fingers.
Old Dec 28, 2005 | 01:47 AM
Zeus's Avatar
considering the fact that dropping a lifter probably requires another 9 hours of work to get it back to its rightful place, isn't it worth the effort to use a dowel?
My wooden ones cost I think $1.17 a piece, and gave me excellent piece of mind.
Old Dec 28, 2005 | 08:20 AM
Mike94ZLT1's Avatar
I said screw it and bought the actual tools about 2 years ago, and they have served me well several times. About to use them again, this time on the Vette. I don't want to deal with broken wooden sticks, or lifters sliding past rods that are too small.
Old Dec 28, 2005 | 08:27 AM
TA TECH's Avatar
As easy as the wood ones slide in ya would have to be a tard to break them and they a hard hard pieces for wood! I always sand them down to make em extra slick!
Old Dec 28, 2005 | 10:04 AM
Nine Ball's Avatar
LS1Tech Co-Founder
The wood ones work just fine. There really isn't anything that can cause them to break, they just slide in and out.
