Question Installing Rollmaster Timing Set +2 Cam Adv.
Old Dec 29, 2005 | 03:10 PM
Greg_E's Avatar
Default Question Installing Rollmaster Timing Set +2 Cam Adv.
The one week I need the search function, and it's not working. That's my luck.
I want to install the timing set so I have +2* advance at the cam.
If I'm understanding the instructions, I install the crank sprocket two keyways to the left of the keyway with the dot (counterclockwise looking from in front of the engine).That would be +4*.
From the +4* keyway I then count 2 1/2 teeth (also to the left) on the sprocket and mark that tooth. That would maintain the same relationship as the two standard dots just shifted two keyways to the left (countercockwise).
I then install the cam spocket, and align the factory dot on the cam sprocket to to the mark I made on the crank sprocket tooth (not the keyway). That will give me +2* advance at the cam .
DoI Have That Right?
Old Dec 29, 2005 | 07:20 PM
Greg_E's Avatar
Anyone? I'd like to wrap this up tomorrow.
Thanks.
Old Dec 29, 2005 | 09:40 PM
Greg_E's Avatar
Finally got the search to work. I think I'm all set.
Here's the link that better explains what to do.
http://support.summitracing.com/scri...ted=1044552136
