need some compression figuring help
Old Dec 30, 2005 | 11:59 PM
69firebird's Avatar
Default need some compression figuring help
HI,
I have a flat top piston and 5.3 heads what kind of compression am I at?
and can I use a thicker head gasket to lower the comp some?
THanks
ed
firebird455@gmail.com
Old Dec 31, 2005 | 12:07 AM
joshp14's Avatar
how big are the chambers on the 5.3 heads and what is the size of the gasket compressed?
Old Dec 31, 2005 | 10:33 AM
69firebird's Avatar
the chamber size is what ever the stock 5.3 is which I think is 62 but Im not sure
the gasket is a felpro that I have now
thanks
ed
Old Jan 1, 2006 | 12:53 PM
joshp14's Avatar
With .002" piston to deck height and a .040" compressed gasket you will be around 11.1 CR. With a .050" compressed gasket you will be at 10.8 CR. Those are both with the 62cc chambers you said above.
