stock motor, new cam?
Old Jan 1, 2006 | 06:54 PM
99TransAmM6's Avatar
Default stock motor, new cam?
ok..i need some suggestions on a new cam. its all stock except for exhaust. i dont really want a huge cam but something that will wake it up and make it run good. its my daily driver also. any suggestions??
Old Jan 1, 2006 | 07:01 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I say the F13
Old Jan 1, 2006 | 07:09 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
MS3 I hear that they idle good at 1k.
j/k!
But to answer your question: f11, f13, or f14 even would do the trick. upgrade your valvetrain with whatever you choose though.
Old Jan 1, 2006 | 07:43 PM
Lithium's Avatar
LOL I was suriously more shocked at that then the having no oil pressure come up.
Old Jan 1, 2006 | 08:08 PM
so i should upgrade springs as well or all of it?
Old Jan 1, 2006 | 09:23 PM
Z28_Ninja's Avatar
springs, oil pump, and timing chain are the minimum that you have do. you can do retainers, pushrods and everything but is not needed for a cam swap.
Old Jan 1, 2006 | 09:25 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Pushrods needed pretty much indeed.
Old Jan 2, 2006 | 12:17 AM
y would i need an oil and timing chain??
so oil pump, springs, and chain and possibly pushrods....man this is gettin expensive..lol
Old Jan 2, 2006 | 12:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And it will.
Old Jan 2, 2006 | 01:41 AM
98A4LS1's Avatar
Yep $$ and it never ends. LOL. Sure is fun though! At a minimum, valve springs, push rods, oil pump, and timing chain.
Old Jan 2, 2006 | 06:44 AM
!LS1 11 Second Club
HP=$$$
Old Jan 2, 2006 | 04:11 PM
Camaro99SS's Avatar
Take a look at Futral Motorsports line of cams. The F6 cam on a 114 LSA would work pretty well for what you want. If you don't already, you really should get a set of long tubes before or the same time as the cam install. To get the best gains with a cam, LT's are a must. You could also look into the Cheater cam. It's around 211/230 with a wide LSA. It'll sound like stock and would work ok with the stock manifolds.
Jason
Old Jan 11, 2006 | 08:59 PM
Jason
oh i aint going for anywhere near stock sounding..i like a nice loud lope at idle...but i dont want to put a cam bigger than what the stock heads can handle if that makes sense i guess...still learning the ls1...but i want power and good strong "unstock" lope
