LS engine block question???
I am about to get a 5.3 truck engine out of a 2002 avalanche for free. I guess the engine has a lower end noise so it was replaced. I am going to take the heads off and use them on my 2000 trans am after gettin a valve job and port work. I guess my question is, what is the 5.3 bore size because i am thinking of useing that block for a 355 low compression engine? Also is the 3.905 a 355?And is the crank that is in the 5.3 the same that is in the 5.7 and if so, what is the max hp for that crank?
Thx rob
But hey i could be wrong
off the wall guess for 355 cid in a gen III small block 3.96X the thousandths it the number you should be playing with, a 347 is still a strong running motor not sure why your tring to get a 355 jjust remember a 5.7 LS1 is 346cid
stock bore for a 5.3 is 3.78 i think
thx rob
