A good start?
Old Jan 3, 2006 | 01:40 AM
'00 Formula's Avatar
Default A good start?
With this setup how much hp and torque do you guess I'd be putting down in a '98 Formula?
MagnaFlow Performance Exhaust Kits
Subframe Connectors
Dynomax Super Converters
Panhard bar
torque arm
224/224; .581/.581 112LSA
harden puchrods and seat springs and other stuff for a cam upgrade
Underdrive Pulleys
Electric Water Pump
ported Throttle Body
3.73:1 gears
12 bolt rear end
SLP cold air intake
Would I need a new clutch, flywheel and driveshaft? Also what about new shocks and brakes, would I need those or would I be fine with the stock ones.
Old Jan 3, 2006 | 10:06 AM
Black FormulaLs1's Avatar
should be fine w/ stock brakes and pads for now but i would upgrade to hawks pads..and definately get some long tube heddars..personally i like my slp ceramic coated LT's..easy to pu tin..and can get to your own plugs..unlike the pace setters...and a spec 2 would help a good bit..
