After ordering H/C...... Do I also need these parts ??
Old Jan 4, 2006 | 08:37 PM
UpToVT's Avatar
Default After ordering H/C...... Do I also need these parts ??
I was wondering if I needed these parts also for doing a H/C package ???
A new Timing Chain ????
Gasket Kit...... Of Course..
new Ls6 Oil Pump on my 99 LS1 ???
Pushrod length . 7.4 ??
Thanks for your help ??
Any have gone with the TSP packages ???
Old Jan 4, 2006 | 08:44 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
IT would be in your best interest to do the timing chain and the oil pump upgrade. The timing chain could be an LS2 or one of the many double rollers. I think that New Era has their double roller on sale for 99 bucks. <-------- hell of a deal!
7.4 on unmilled heads or even 7.45.
If they are milled you might be looking at a different length.7.3,7.35's
What heads and cam are you thinking of getting?
Lotsa people have gone the TSP route! You should get a bunch of feedback.
Old Jan 4, 2006 | 08:47 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
X2 everything said.
Old Jan 4, 2006 | 09:07 PM
UpToVT's Avatar
I was thinking of getting the Texas Speed Torquer v.2 Camshaft,
Now which rods should I get the 7.400, 7.375 or 7.350 ???
Should I go with the rollmaster double roller adjustable timing set ??? or single non adjustable.
The oil pump the offer is the TWP LS6 Ported fuel pump ???
I have 99 Vette M6 with 3.90's, kooks, vararam, LS1 Edit, are my major mods.
I was wondering is this where I should be heading also.........
I appreciate it
Thanks
Old Jan 4, 2006 | 09:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I know that Predator Z has been very fond of that cam and had sweet results. Shoot him a PM and see what he suggests as far as pushrod. I believe that it would be 7.4 or 7.45's
Old Jan 4, 2006 | 10:27 PM
!LS1 11 Second Club
I appreciate it
Thanks
No need for the adjustable timing set unless you're going to advance or retard the cam. Single, LS2 or single aftermarket is fine.
Ported LS6 oil pump is fine too.
Your 3.90 gear will work well with the TSP Torquer II. It will make for a nice setup.
Old Jan 4, 2006 | 11:39 PM
PREDATOR-Z's Avatar
I appreciate it
Thanks
With .054 Grapghite gasket, I used 7.425 p-rods (Got them from Thunder, Comp Cam).
I use a single chain, J-Wiss that I had before with stock oil pump. If I had to change chain I would use LS2.
Old Jan 5, 2006 | 02:22 PM
UpToVT's Avatar
Thanks
Pred Z do you have that Cam from TSP ???
If so how do you like it ???
Any comments towards my set up ?
