rod bolt change out
Old Jan 5, 2006 | 08:32 PM
Ssnc4's Avatar
Default rod bolt change out
Is there any way in hell to change the rod bolts on a 98 SS with out pulling the motor i really dont want to do that since i just have it almost ready to pull cam swap i was told after the fact that the rod bolts are junk and i should change them
Old Jan 5, 2006 | 08:51 PM
DocEwww's Avatar
Originally Posted by Steve Burger
I did it while changing the K Member. I used a 4x4 peice of wood accross the shock towers and some good straps around the headers to support the engine. I also had a jack under the trans.
It worked for me and we have done a few of these.
Oh and you will be amazed at how easy it is to get the oil pump pickup tube and O ring this way.
From the other current thread...dunno if you saw it.
Old Jan 5, 2006 | 08:58 PM
Ssnc4's Avatar
Thank you very munch so drop the K member and get a cherry picker to hold the engine
Old Jan 6, 2006 | 07:56 AM
Steve Burger's Avatar
LS1TECH Sponsor
No cherry picker, just a 4x4 post of wood cut to the lenght of the shock towre brace. Also no need to completely remove the K Member. It will makre it a lot easier though. And if you remove the stock K Member I would not replace it.
Yeah, snowball effect.
