Why are some stock engines better than others???
Old Jan 7, 2006 | 10:47 PM
BriancWS6's Avatar
Originally Posted by Quickin
Using LS1 parts wouldn't add any hp though. Unless it was the LS6 intake or cam from the Vette LS6's. Maybe thats what they did? Sneaky sum-bitches.
He said they used LS6 parts cause they ran out of LS1 parts. But of course we all know the only parts that LS1s got from the LS6 came in 01/02, and those are the LS6 intake, and a small percentage actually got the LS6 block (no diff in hp with the block) There were also other things these models got over the previous years, like LS6 oil pump, stronger rod bolts, and LS6 clutch and hydraulics if a m6.
And this is on all f bods of the 01/02 year models
Old Jan 8, 2006 | 05:30 AM
Patman's Avatar
I've often wondered why there are some LS1s out there that burn tons of oil and get piston slap, but then there are others (like mine) which use virtually no oil at all (my dipstick level is unchanged in over 8500 miles since I last changed the oil!) and have no piston slap at all. I guess there is a huge variance in how they build them, the quality control must've been pretty relaxed.
Old Jan 8, 2006 | 05:39 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by SUX2BU
the fast ones were built on wednesdays.
Thank goodness mine was born on a Wed.
