what spings and such
Old Jan 7, 2006 | 09:35 PM
purple98haz28's Avatar
Default what spings and such
i just got a patriot performance 226 585/585 112 lsa cam and was wondering what springs should i get. do i need to change pushrods. anything else that i need?
Old Jan 7, 2006 | 09:47 PM
Lithium's Avatar
SSU's Drunk Typing Whore
918's springs, hardened pushrods, ls2 chain, ported ls6 oil pump.
Old Jan 7, 2006 | 09:53 PM
BriancWS6's Avatar
The 918s as mentioned above are good to .600 lift. With that being said I like the extra security of duals when getting that close. Alot of people have ran even closer to that .600 with the 918s though.....so it's your call.
FWIW I ran the patriot duals when I had the TSP 225/225 .589/.589 cam in my previous car, I liked them just fine.
Old Jan 7, 2006 | 10:42 PM
Randy WS6's Avatar
Go patiot Gold there duel springs and good for .650 lift and will last longer because of less stress and the added inserance of duel spring so if one breaks you want drop a valve and granaid you motor and the price is not that much differance,Ive run the gold's for over two years now with the T-REX .609/.614 lift at rpm upto 7600 and not had any problems at all with the springs
Old Jan 7, 2006 | 11:18 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
both are good choice.
Wnts2Go10O's Avatar
918's or patriot golds
Old Jan 8, 2006 | 11:37 AM
are pushrods, timing chain and oil pump a must right now? i will prob do it anyways cause i have 96k on motor. just wondering
Old Jan 8, 2006 | 08:32 PM
BriancWS6's Avatar
Yep, especially if you don't have an 01 model which already has the LS6 oil pump.
Old Jan 8, 2006 | 08:35 PM
ok thanks
Old Jan 9, 2006 | 09:55 AM
Gunnar@Patriot's Avatar
The Patriot Golds are a great choice. They are $255.00 for the complete kit with springs, ti retainers, super 7 locks, machined spring bases, and viton rubeer seals. You will be well pleased with their performance.
Old Jan 9, 2006 | 11:39 AM
SCHUMAKERPERFORMANCE's Avatar
I just installed the patriot springs and they look very nice. I would definently recommend them. I also have the same cam.
Old Jan 9, 2006 | 02:58 PM
Glad to hear you liked the products we sent you ! Many customers are enjoying our quailty products. Our heads and spring kits are the best value on the market.
