Questions about larger cams
There is a decent amount of info available if you search. The X3 will fit under stock heads, even on a 112, but it is close. I believe the X4 will fit on a 114.
The G5X series cams are all traditional splits.
https://www.horsepowerengineering.co...YNOCAMONLY.jpg
i would guess that the x4 would fit without flycutting on any lsa. i think the "base" x4 is on a 111. the t-rex is advertised at 242/248 on a 110, more like 244/249 109 lsa from the cam cards i've seen...so theoretically the x4 would fit with much room to spare.
Really, what is the best way to look at a cam and determine if valve clearance is going to be, or could be, an issue?
Dial indicator measurement is the way to do it.
I'm really looking harder at the T-Rex now, because it seems like it'd offer more potential with aftermarket heads, because of the lift numbers, although the G5x4 looks pretty damn good in that area, also. When I swap to a different set of heads, I'll just have the pistons pulled, spec'd, and flycut accordingly. I'll definitely be using either Crane 921s or PP Duals, although that'll take a bit more research for me to decide on. Definitely a hell of a lot bigger cam than I started out wanting - the 224/224
