head swap
can I install headers from top once I remove heads? anybody done this before? if yes any pointers would be appreciated. posted this here since it's w/ stock heads being swapped w/ PP.
thanks
fuerzaws6
thanks
fuerzaws6
I did mine from top. If you have a lift it helps a ton though. But yes you can do it.pull the old heads put the headers in. then put the new heads on. you should have no problemes.
