Lookin for a torque monster
Old Jan 10, 2006 | 07:42 PM
Bombguy99z28's Avatar
I run a 220/220 581/581 110lsa 106icl on 5.3l heads milled to a 55.4cc chamber. It doesn't hit the valves, but probably doesn't have very much clearance.
Originally Posted by Teutonic Speedracer
That's the cam I just put in. Everybody's got me scared of PTV clearance now with my heads milled .030. I've got checker springs on the way, and I need to sort out my pushrod length and rocker arm height 1st. Since so many of you recommended that cam, is their anyone here that has run the cam with no PTV issues?
Old Jan 10, 2006 | 09:36 PM
Ragtop 99's Avatar
Do you have a dyno of that? Very early IVC so i was curious to know where peak HP occurs and how far it carries.
Old Jan 10, 2006 | 10:05 PM
P Mack's Avatar
My c1 cam was an awesome torque cam. It's for sale if you're interested.
Old Jan 10, 2006 | 11:53 PM
krexken's Avatar
I wonder what the DCR is on that setup?
Old Jan 21, 2006 | 02:16 PM
Teutonic Speedracer's Avatar
Default Finally got back to checking geometry
Here is what I came up with:
Prod Length (")/Valve Swipe(I->E)/Pre-load (turns)/Rocker Shim I (")
7.300 / 1/3-1/2 / 1/2+ / 0
7.338 / 1/3-1/2 / 1/2 / .031
7.375 / 1/4-3/4 / 1-1/2 / .031
7.375 / 3/10-7/10 / 1/2 / .062 (Exhaust)
7.375 / 3/10-7/10 / 1/2 / .062 (Intake)
7.375 / OK / 7/8 / .046
So, I think I may pick up an .064" shim to get a little less than 1/2 turn of preload, and then move on to checking my PTV clearance. Just thought I would share my results. The swipe is rough and hard to nail exactly.
I also measured the travel of an 8mm x 1.25 bolt. One turn of the bolt equates to ~.059". This does not necessarily mean that is what the turn of the bolt is the same as the preload on the lifter....but it should be close.
Old Jan 21, 2006 | 03:15 PM
Viper's Avatar
Thanks, I needed that!
Old Jan 21, 2006 | 04:17 PM
Just remember that is with MY setup. It is best to check yourself. My setup is heads milled .030, 1.455" base circle cam, Harland Sharp rockers, LS6 Valves, etc. So there are a lot of things going on. Hopefull it can at least be some type of reference!
Old Jan 22, 2006 | 06:35 AM
PREDATOR-Z's Avatar
Hi Teutonic.
So from your 7.375 measurement with .062 shim you got .5 turn or as per your measurement .059 preload / 2 = ~.0295 cold
Isn't that a bit loose ??
(let me know if my assumption is incorrect)
Old Jan 22, 2006 | 07:40 AM
Viper's Avatar
Of course.
Old Jan 22, 2006 | 09:24 AM
MNR-0's Avatar
Originally Posted by MNR-0
Want a torquer cam?
Small cam (intake in the teens)
Tight LSA (112 or less)
Split duration (to help it breathe and give you an extra 100rpm)
High lift (above 560)
It will idle at 700rpm and pull STRONG through the mid-range. I picked up 40rwhp by doing exactly this but mostly the torque gains are incredible. Made my 3000 stall into a 3600 stall.
Oh yeah - with this setup and sticky tyres 11s are gimmes for an otherwise cam only GTO.
Results in. 11.9@114. Need more proof? 212-220-112+2
Old Jan 22, 2006 | 09:39 AM
Originally Posted by PREDATOR-Z
Hi Teutonic.
From all I've read in these posts (pre-load vs. pump-up), LS1howto, my mechanic, etc. it seems that about a half turn is pretty good. I will be changing springs and checking things yearly (~2k) miles. I was under the impression that the factory overdoes the preload to account for wear over 100k miles.
Old Jan 22, 2006 | 09:48 AM
  #32
PREDATOR-Z's Avatar
Humor me and add .025 to your calc and your preload would be more in the range it should be
.0295+ .025 = .0545 (recomended .060>.080 cold)
I still think the 7.40 are the ones.
Old Jan 22, 2006 | 10:49 AM
  #33
Felix C's Avatar
would a 112+2 be the same as 114?m Or would it be the same as a 110?
Old Jan 22, 2006 | 10:50 AM
  #34
Pred-
I see what you are saying, but that .060-.080 is on a stock motor with the intent of not being opened up for 100k miles to replace and adjust things. I've read so many posts where .015-.030 seems fine. What about the info on LS1howto for the YT install? "Every car will be different so make sure you check this! You want the smallest number of turns you can get, as long as you have at least 1/4 or 1/2 full turn of preload in there once you are all setup."
I'm not trying to disagree, just trying to find why you say so much pre-load?
Old Jan 22, 2006 | 10:56 AM
  #35
hurley711's Avatar
Will a TR224/224 .563 .563 on a 112 add good low end torque? Like in the 1800-4500 range?
Old Jan 22, 2006 | 11:15 AM
  #36
PREDATOR-Z's Avatar
Pred-
Yeah, I see your point, it is just that you are gonna use this as sustained rpm use, oil will thin out, bleed down will be faster, so keeping lifters pumped up at higher level will be more difficult and valve float is an issue you want to avoid.
I would set my pre-load hot just to be sure.
Depends what kinda oil grade you'll be using also.
Old Jan 22, 2006 | 11:20 AM
  #37
Cool, that makes sense also. Well, I have an oil cooler on the car which keeps my oil temps in check. I also drilled holes in the lifter trays to reduce the foam and allow them to drain properly. I'm running M1 5W30. I can't check it hot at this point as I am getting the geometry correct to verify PTV clearance, then I need to put the rest of the motor back together before I can start it and run it.
Thanks!
Old Jan 22, 2006 | 04:13 PM
  #38
peter pan's Avatar
Well if you go with a forged 346, DS1C and comp cam 224 581 on a 114 LSA the torque is there I know I got 645 lbs of it, and at 3k I got 350 and then it pulls like rape@ ape, and it is just incredible to have this much power always ready when you decide to stomp the blowin Stang
Old Jan 22, 2006 | 04:16 PM
  #39
Viper's Avatar
FWIW, .030 is for the Morel lifters, 850-16 and stock can go .060-.080 from what I've read.
Old Jan 22, 2006 | 04:26 PM
  #40
SideStep's Avatar
No. 112+2 means = 112lsa with a 110icl
