LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Installing Oil pan. What's the white sealant? (https://ls1tech.com/forums/generation-iii-internal-engine/433593-installing-oil-pan-whats-white-sealant.html)
Greg_E Jan 8, 2006 03:18 PM
I'm Installing the oil pan after replacing the rod bolts, cam, timing chain and oil pump.
I noticed when I dropped the pan, that GM used some type of white non hardening sealer in the corners. It looks like they used it in the spots wherever three casting meet. Timing cover, block and oil pan or rear main cover, block and oil pan. Is this some special sealer or is it just pipe thread sealer? Can I just use a dab of silicone sealer in those areas, and if so, what is the correct one to use? Permatex copper, black, blue, red. They all have slightly different properties.
Thanks.
Greg_E Jan 9, 2006 04:46 AM
Anyone? :confused:
Zeus Jan 9, 2006 05:32 AM
I installed two oil pans recently and I didn't use any sealant or compound of any type save for Loctite. I just finished up a 14hour drive and there's no leaks to speak of.
I know this doesn't answer your question, but I guess what I'm trying to say is it's not the end of the world if you don't figure this out.
camaross305 Jan 9, 2006 08:50 AM
i just also recently dropped the oil pan for my oil pump swap and just used a little bit of high temp permatex were the timing chain cover and pan meet and havent had any problems after a 6 hour drive.
© 2026 MH Sub I, LLC dba Internet Brands
