MS3 cam?
Old Jan 8, 2006 | 10:22 PM
stangkiller99ss's Avatar
Default MS3 cam?
i have a 99 ss with airlid, cutout, 75 nx dry shot, 4:10 gears, 85mm mafs, superchips programmer, i was wanting to know if the ms3 cam is a good cam having stock heads?
or what are some of the better options of cams having stock heads?
Old Jan 8, 2006 | 10:29 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Your setup sounds like a good candidate for an MS3 (gearingwise).
You do need Long Tube headers first.
If no LT's then check out Thunder Racing's CheaTR cam.
Old Jan 8, 2006 | 10:32 PM
SSilverSSurfer's Avatar
cheater cam is pretty bad ***
Old Jan 8, 2006 | 10:36 PM
blkZ28spt's Avatar
You need headers before any real cam goes in.
Search around. I'd consider putting the stock MAF (singular) back on. You programmer will do you no good, you need a proper hands on dyno tune, HPTuners, LS1 edit, etc etc.
Old Jan 8, 2006 | 10:42 PM
ya sorry forgot to mention i have pacesetter coated lt on their way
Old Jan 8, 2006 | 10:44 PM
!LS1 11 Second Club
^ Then what are you waiting for, order the MS3 already! Hehehe.
Old Jan 8, 2006 | 10:49 PM
so then you think that it is the best cam out there that i can get the most power from?
Old Jan 8, 2006 | 10:51 PM
Lithium's Avatar
SSU's Drunk Typing Whore
pretty much...theres always the Trex
Old Jan 8, 2006 | 10:52 PM
also what other stuff would i have to get to install this cam?
Old Jan 8, 2006 | 10:54 PM
!LS1 11 Second Club
It's one of them.
TRex, TRak, F14, F15, G5X3 are a few others.
Each has more or less the same peak potential, they will differ slightly in area under the curve.
Old Jan 8, 2006 | 10:59 PM
!LS1 11 Second Club
Read the list on www.ls1howto.com cam install.
Springs, retainers, pushrods, timing chain (good to do on a '99), may want to do oil pump. TUNE.
Old Jan 8, 2006 | 11:13 PM
TheBlurLS1's Avatar
That's what she said...
Also a nice camshaft to check out is the HPE S-cam.
Definatly need a good dynotune as well. You can get a custom nitrous tune (less timing etc.) and step up to maby like a 100-150 wet shot.
I have the futral F14 in my car and love it. I also have big gears (4.11's) and i love it when the cam screams up top.
Old Jan 8, 2006 | 11:31 PM
oh yeah
