Do heads really make that much of a difference?
Old Jan 11, 2006 | 01:31 AM
zkiller_85's Avatar
what about swapping in some 6.0l heads? whats the gain over stock?
Old Jan 11, 2006 | 01:37 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
As 6.0L heads may have the same port design as LS6 heads (good), but the combustion chamber size alone will drop compression significantly (bad).
6.0L heads are usually welded up in the chamber to reduce chamber volume. Patriot's "LS6 Style" heads are a perfect example. They're available in 59cc.
Old Jan 11, 2006 | 10:43 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Heads will typically gain about 35-40rwhp. I just recently finished up a brand new PRC ls6 port that flows some crazy air I'm going to be setting up some dyno results soon so keep your eyes open & I'll post up the results!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
