TSP Torquer v.2 too big for DD?
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
F11, Stock heads
F11, stock heads, vs ported
F11 Stock heads, cats
F11, stock 243 heads
Im running 3.73gears and a 4000...but this is a daily driven street car in the summer.
I was considering this cam also I just did not really want to shift past 6500....I don't really want to spend the time replacing rod bolts on this motor....
I got a call from our shop(SN is "SRP" on here) last year asking to come down and look at what was left of this LS1 block that came out of a 98 TA. The #5 and #6 rod bolts had let go in this thing at high rpms and the block was toast. I had them change my rod bolts(to ARP) and rod bearings while they were making my true duals and my #5 & #6 rod bearings were starting to show abnormal wear compared to the other six.
My advice- if you're gonna run a 98 up past 6000 rpms, change those rod bolts. Do a search on here, it's actually not that hard to do.
One reason I say for pure street 22x range cams are plenty, but at the track, the big boys will shine.
tr224 fm13
rpms hp tq hp tq
2700 - 170, 331 .. 163, 313
2800 - 181, 338 .. 167, 313
2900 - 189, 342 .. 172, 313
3000 - 200, 348 .. 182, 316
3100 - 209, 355 .. 187, 319
3200 - 219, 360 .. 200, 327
3300 - 229, 365 .. 210, 333
3400 - 238, 368 .. 219, 338
3500 - 245, 369 .. 227, 341
3600 - 254, 371 .. 237, 345
3700 - 263, 374 .. 246, 348
3800 - 273, 376 .. 253, 350
3900 - 279, 377 .. 262, 353
4000 - 288, 377 .. 270, 355
4100 - 296, 378 .. 278, 356
4200 - 303, 379 .. 285, 357
4300 - 310, 379 .. 293, 358
4400 - 319, 380 .. 301, 359
4500 - 327, 383 .. 309, 361
4600 - 339, 385 .. 319, 364
4700 - 346, 387 .. 330, 367
4800 - 353, 387 .. 338, 370
4900 - 362, 388 .. 346, 372
5000 - 368, 387 .. 354, 372
5100 - 374, 385 .. 361, 371
5200 - 379, 383 .. 366, 370
5300 - 384, 380 .. 371, 368
5400 - 389, 377 .. 378, 367
5500 - 392, 375 .. 383, 367
5600 - 395, 371 .. 390, 365
line graph goes beyond 5600 rpms, this was a print out of the numbers. I'm sure I dont have to convince anyone the fm13 had more peak.
Come on man, DD for you is if it starts
tr224 fm13
rpms hp tq hp tq
This is great data to look at. Thanks!
