Turbo motor
Old Jan 12, 2006 | 11:13 PM
02URPITFUL's Avatar
Default Turbo motor
For a streetable turbo car, what is the most reliable motor to use?
I was thinking of getting a 6.0 iron block but not sure if all that is needed.
Old Jan 13, 2006 | 07:12 AM
slow trap's Avatar
the iron 6.0 is definitely strong but since you're mostly going to drive it around on the street your motor is probably not a max effort so i'd say just get a dish 402 ci ls2 with the eagle/mahle combo with hell fire rings and you'll be fine. how much hp are you wanting?
Old Jan 13, 2006 | 08:39 AM
777's Avatar
777
Basically any forged lsx motor is strong enough for 1000+rwhp. I'd be concerned with weight and price. I'd stay away from iron. If you want big cubes go ls2 if you want a 34X stay with the ls1/ls6 block.
Old Jan 13, 2006 | 03:32 PM
02URPITFUL's Avatar
Loooking for about 700-800hp. Thats about all i think i would need.
What is the main difference in the LS1 and LS2?
Can i go from a LS1 to a LS2 with little trouble?
Old Jan 13, 2006 | 04:13 PM
THE_SUPRA's Avatar
bore is teh big difference that and the ls2 has slightly better knock sensors. the heads/accessories are interchangeable between the two
Old Jan 13, 2006 | 04:39 PM
jyeager's Avatar
There is a general issue with hooking the LS2 knock sensors to your computer as well as the difference in the cam signal.
If you only used an LS2 block, but built it with LS1 parts you can't mount your knock sensors and have to remove the knock sensor behavior from your computer.
Consider this: if you are boosting then you can easily make your power goals without having to use the LS2 block, hence no transplant issues.
Old Jan 13, 2006 | 05:26 PM
XtremeDime's Avatar
what if i were to do a mild turbo setup on an ls1? what would i need?
Old Jan 16, 2006 | 07:18 AM
jyeager's Avatar
Mild? I'll assume that means 8-10psi max? Well, stock crank with better rods and pistons with good ARP bolts and studs.
But if you are building a fresh motor, you might want an Eagle stroker kit which gives you a better crank with more cubes. And of course, you can then build it for the boost in such ways as just a little more piston clearance and ring gap and dished pistons for less compression.
