thread size/pitch of coolant temp sensor in head?
I have an electric temp sensor im trying to put in the other head and I need to obtain an adapter of some sort.
Thanks
Dave
Thanks
Dave
Are you talking about the one that goes above the starter, if so M16x1.5 is the thread pitch. You'll need a 1/8" to M16x1.5 adapter. Use this thread to find where to buy one.
https://ls1tech.com/forums/generation-iii-external-engine/391271-ntp-metric-adapter.html
Thanks
Dave
Thanks
Dave
The same as the end accesory bolt holes, it just looks different because of the counterbore.
is it 10 or 16? Im talking about the plug on the side of the head by the back of the last exhaust port where I can pull the plug out to put this sender in. Its the same hole they put the PCM ECT sensor in on the other head.
Dav
Dav
Originally Posted by under_construction
It's actually 12x1.5mm thread, autometer and others make adapters to go from 12x1.5 to 1/8 NPT for most temp sensors.
So that would be 12mm X1.5. I used a thread pitch gage to
check the 1.5 Dale
The oil ports are 16 x 1.5, the water is 12 x 1.5mm
Here's where I got mine;
http://www.isspro.com/products.php?cat=2
