deck height ?
Old Jan 16, 2006 | 03:54 PM
rck329's Avatar
Question deck height ?
Hey guys,
What's the deck clearance (distance from top of piston to block deck) on a stock LS1? Negative right (piston in hole)?
Thanks
Old Jan 16, 2006 | 04:11 PM
Gunnar@Patriot's Avatar
On a factory LS1 the piston is out of the hole. A negative number means the piston is above the deck and positive means it is below the deck.
WS6store.com's Avatar
LS1TECH.com Sponsor
Approx .000"-.002" based on the following specs:
67.3 cc Combustion Chamber
0.00 cc Piston top volume
3.9" Bore x 3.62" Stroke
.052" Compressed gasket
Old Jan 16, 2006 | 04:23 PM
rck329's Avatar
Oh, they are positive... Gunnar do you know how much?
I guess I just need wrist pin CL to piston top distance. I have all the other numbers.
Old Jan 16, 2006 | 04:25 PM
Beast96Z's Avatar
Originally Posted by rck329
Oh, they are positive... Gunnar do you know how much? 0.005?
There not all going to be the same. They average about .005"-.010" out. Most just say .007 if trying to find compression and so forth. It's as close as you'll get without actually measuring.
Old Jan 16, 2006 | 04:28 PM
rck329's Avatar
Gotcha. I guess I'll go with the 040 gaskets instead of the 030 then.
OK, part 2... does anyone make a 040 graphite head gasket with 3.9 bore?
Old Jan 16, 2006 | 04:38 PM
Beast96Z's Avatar
Nope. The only people that make a broad selection for the LS1 is Cometic and they are MLS.
