347 Vs 382/3
Old Jan 17, 2006 | 10:13 PM
b727pic's Avatar
Default 347 Vs 382/3
Planning a rebuild. engine is out and torn down. Time to start picking parts to go back in.
Simple question, those who have stroked what are your impressions immediately after the change....
was there a noticeable difference in low range torque??
is it worth the cost of the crank to make it happen??
I have decided against the 408 for the time being, so my decision is based solely on what can be done with my existing block.
I am running boost, a procharger currently @ 10PSI.
Old Jan 18, 2006 | 12:53 AM
1badA3Z's Avatar
i say go for the more cubes,build a 383 with good parts so u can up tha boost,cause if u dont now u mite regret it later,jmo tho
Old Jan 18, 2006 | 06:17 AM
1FASTLS's Avatar
Default go more cubes
You can't beat cubic inch, have you looked into the 402, I was going to go back with my 382 but the cost was not that much more for the 402. But at the same time I really see alot of horsepower coming out of the 347 with a power adder not to say they didn't do a lot of top end mods.
Old Jan 18, 2006 | 06:29 AM
SAM98WS6's Avatar
yes
yes
Old Jan 18, 2006 | 10:20 AM
b727pic's Avatar
I was leaning towards a 402 until the Knock Sensor's became an issue. I understand that physically they can be connected, but last I researched it was an issue getting the LS1 ECM to work with the relocated sensors. Someone posted pin outs, I don't want to get into rewiring.
So unless someone has an update on the KR sensor issue, I have decided against an LS2 block. Would love to hear that issue is resolved!!!
