Need some advice/help
Old Jan 18, 2006 | 03:32 PM
supersteve7's Avatar
Default Need some advice/help
I have a 2002 ss camaro. I just put
Corsa High Performance Exhaust
K&N Fuel Injection Performance Kit II
Hypertech 160 degree Thermostat
ASP 540120 and Crank pulley, and belts
SLP High Output Mass Air Flow Sensor
SLP Smooth Bellow
SLP long tube headers
SLP y-pipe
SLP high flow catalytic converters
Comp cams duration @.050 intake 222 exhaust 224
lobe lift intake .3330 exhaust .3340
lobe separation 112.0
Comp cam lifter and beehive springs
i got it back and it wouldnt idle or driveright. when i had this guy from efi reflash the computer, it would idle,and drive ok, but lower rpms and idle in drive still messes up or bogs down. any ideas whats going on? i think i should have done more research before doing this. but its too late now and i need your help guys!
