What size pushrod?
Old Jan 19, 2006 | 12:33 AM
fastmatt98's Avatar
Default What size pushrod?
For a head milled 30 thousandths?
Old Jan 19, 2006 | 09:28 AM
Xtnct00WS6's Avatar
How big is the base circle of the cam? What about headgasket thickness?
I'm trying to figure mine out and I think the best you can do is approximate and then measure to be absolutely sure. I'm going to get a pushrod length checker from Thunder and I'd suggest you do something similiar so you know exactly the right size.
The sticky in this section (ls1-ls6 internal) has a link to a pushrod length calculator in the pushrod section that you should check out.
