better flow- 5.3L or 5.7l?
Old Jan 19, 2006 | 09:23 AM
Felix C's Avatar
Default better flow- 5.3L or 5.7l?
Do 5.3L heads fitted with 5.7L sized valves flow better than stock 5.7L LS1 heads?
Do either head have an advantage once 2.02/1.57 valves are fitted?
Other than smaller combustion chambers for higher compression, is there any characteristic of a 5.3L which would be superior to a 5.7L?
This is for street NA use with camshaft lifts below .581".
Old Jan 19, 2006 | 09:29 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
TEA Stage 1 5.7L Heads retain stock valves and provide stellar low to mid lift flow numbers, for about $1000.
Their 1.5 5.3L head will outperform them past .550 lift.
Old Jan 19, 2006 | 09:36 AM
Felix C's Avatar
I can obtain stock(unported) LS6 heads for about $1000. Would these be a better alternative to a lightly worked 5.7L or 5.3L(with larger valves)?
Considering a GT2-3 or similar stealth camshaft.
Old Jan 19, 2006 | 09:40 AM
!LS1 11 Second Club
^ Ah, I was talking about 241 castings, not 243's.
For $1000, check out Texas Speed, Patriot and Livernois for their CNC ported 243 casting LS6 heads, assembled. They're as cheap as $850.
To answer your question, either the ported ls6 heads or a good 5.3 would make a good match to that cam.
Old Jan 19, 2006 | 09:44 AM
Felix C's Avatar
Initially so was I. But thought to add in the other 5.7L alternative after viewing pricing options.
Search function has been rather restricted the past few days. Cannot access older posts.
