timing chain, please need your info
Old Jan 19, 2006 | 05:47 PM
Solid346's Avatar
Default timing chain, please need your info
well i will be changing my camshaft soon and i already have a rollmaster timing chain. due to the fact i dont know if there is a dot on the gear to set it like the factory timing chain.
can anyone advise what to do if i am changing a cam with already cam installed with double chain
thanks
Old Jan 19, 2006 | 06:59 PM
ROCNDAV's Avatar
The Cams are pinned, so there should only be one way to put it on, unless the pin has been removed.
Old Jan 19, 2006 | 07:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have the same chain and cam and crank gear setup. There is a dot bro.
Old Jan 20, 2006 | 04:55 AM
Solid346's Avatar
you mean the red dot on the cam. cause i know that the factory timig chain have dot on it, if the double one has it man i am saved
Old Jan 20, 2006 | 11:15 AM
ROCNDAV's Avatar
My Rollmaster didn't have a red dot, but it does have a dot.
You are speaking of the rollmaster double roller, right?
The Crank gear has a Key and the cam gear has 3 bolt holes and a pinned locating hole.
