5.3 max bore dia. please help
Old Jan 20, 2006 | 05:42 PM
blazerman's Avatar
Default 5.3 max bore dia. please help
hey i have a complete 5.3 and a friend of mine has all the internals for a ls1 minus the block can i bore my 5.3 block to ls1 specs and use his parts to make a budget ls1.
Old Jan 20, 2006 | 05:51 PM
strokedls1's Avatar
You can do that, but the expense of the machine work would be the same price as a used 5.7L alluminum block. Why not stay with alluminum and have a 100lbs less on the nose of the car.
Old Jan 20, 2006 | 07:08 PM
blazerman's Avatar
what kind of machine work would be needed other than the bore of the cylinders.
Old Jan 22, 2006 | 02:14 PM
strokedls1's Avatar
Sonic test to make sure there is enoiugh meat to bore as much as you want. Deck the block. Check main straightness and possiblly do a line hone on the mains. Remove the old cam bearings and install new ones.
