Pulling the timing chain sprocket off the crank?
Old Jan 22, 2006 | 05:17 PM
1BadDime's Avatar
Question Pulling the timing chain sprocket off the crank?
Just wondering how to pull the timing chain sprocket off of the crankshaft, Is this sprocket pressed on, or should it just slide off nice and easy?? Mine is on their pretty tight and I am assuming that i need to get a pulley remover to take this off properly... is this correct?
Thanks in advance...
Jim
Old Jan 22, 2006 | 05:20 PM
jrp's Avatar
jrp
SN95 Director
2 arm pulley puller
Old Jan 22, 2006 | 05:39 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Takes some patience but it was easy for the most part.
I used a three arm puller myself.
Old Jan 22, 2006 | 07:59 PM
01350ss's Avatar
use the same puller that you used to pull off the crank pulley
Old Jan 22, 2006 | 08:59 PM
1BadDime's Avatar
Thats what i thought...thanks guys!!
Old Jan 22, 2006 | 11:23 PM
camaross305's Avatar
mine just came right off is this bad?
Old Jan 24, 2006 | 05:18 PM
99whitews6's Avatar
Not trying to jack the thread, but how do you put the new sprocket on?
Also, does anyone know the P/N for a new key for the crank slot?
Old Mar 27, 2006 | 10:17 AM
waSStock's Avatar
ttt ttt
Old Mar 27, 2006 | 11:24 AM
Ohio Bird of Prey's Avatar
I've used the old sprocket to push on the new one. I've done 3 cams that way and works for me.
