Need a little wiring help please!
Old Jan 24, 2006 | 09:16 PM
Enthusiast's Avatar
Default Need a little wiring help please!
I seem to have broken an end off of a wire when I removed some things that weren't needed. I am not sure if it's the MAP sensor or the CMP sensor but one of the wires was broken. This picture shows the wires I am speaking of in the top left hand corner by the coil packs. It is the brown and red wires. http://img118.exs.cx/img118/1812/STEP13.jpg
I am getting Code P0341 which imples CMP sensor but I am not sure. The car backfires through the exhaust when trying to start and is a real pain to get started. It also idles a little funny. What I need to know is where the end pictured connects to ANYTHING. I have looked all around and can't seem to find out where it connects. The other end of it is still intact. Any help would be greatly appreciated.
Thanks, Kraig.
Old Jan 25, 2006 | 11:55 AM
ROCNDAV's Avatar
The Green Circle appears to be your Oil Pressure sending unit. I can't make out what the red circle is.
Old Jan 25, 2006 | 12:44 PM
Z'mnypit's Avatar
The green circle looks like the oil pressure sending unit is broken off? Did you break it while removing the intake? Its not hard to do.The red circle looks like the vacuum line that runs to the back of the intake. Doesnt look like a wire.
Old Jan 25, 2006 | 01:58 PM
Enthusiast's Avatar
I think I figured it out guys, thanks for all the help. The wires pulled out of the connecter on the end of the Cam Postition Sensor.
Old Jan 25, 2006 | 03:37 PM
Z'mnypit's Avatar
The oil pressure sending unit still looks broke. It doenst plug in like that!
Old Jan 25, 2006 | 03:44 PM
Ωmega's Avatar
They're right, I just broke that thing off last week, first time ever. You cam position sensor looks fine though....
I also can't make out the red circle but the green one is definitely the oil pressure sending unit. It's a pice that sticks up about 2 1/2" from that spot.
