427 heads
Old Jan 27, 2006 | 01:31 AM
LSXRX7's Avatar
Default 427 heads
OK i searched and searched and came up with many differant answers. I am doing A 427 stroker on my ls6 i have LQ9 heads and ls6 heads which head would be better to use if i get them worked over by a shop? if they need to be at all?
or should i get different heads and how much do they cost$$$
thanx
Old Jan 27, 2006 | 01:57 AM
NoGamesLS1's Avatar
I would think that the ls6 heads would flow better, but you'll be at high compression. I'm building an engine right now so this is where Ive been spending alot of my time http://www.diamondracing.net/cocalc.htm
Old Jan 27, 2006 | 02:19 AM
Ferocity02's Avatar
Either head even if ported will still be restrictive on a big 427, IMO. I am planning on using GM LS7 or Warhawk LS7X heads on my 427.
Old Jan 27, 2006 | 08:03 AM
Chris 96 WS6's Avatar
I thought the 6.0 Liter heads had LS6 ports, but bigger chambers. I guess I thought they would have flowed similarly when ported out.
Old Jan 27, 2006 | 09:10 AM
11 Bravo's Avatar
The 6.0L's can get er done. These are my TEA's set up for 4.125.
lift intake exhaust
.100 70.2 59.3
.200 143.4 128.7
.300 216.8 188.7
.400 270.0 232.1
.500 311.9 257.2
.550 330.0 264.0
.600 343.8 268.0
Wish the chart had gone up to .650, would probably have seen 350cfm
Old Jan 27, 2006 | 11:56 AM
Beast96Z's Avatar
That's a correct assumption. After porting, the heads flow almost identical. Most porters, espeacailly CNCers, run the same program wether it's 6.0 or LS6. I would let the compression needed be my determing factor.
Old Jan 27, 2006 | 12:31 PM
LSXRX7's Avatar
so to clear things up if they are going to CNC the final outcome will be the same if the LQ9 are milled. I have the LUNATI rotating assem for a LS6 so pistons are rev. dome.
