Rollmaster Double Roller ?
Old Jan 28, 2006 | 02:04 PM
ashade98's Avatar
Default Rollmaster Double Roller ?
Installing a rollmaster double roller. To set the timing straight up, do I use the dot on the crank sprocket teeth? Like the stock one. I notice that there is another dot on the snout? Just want to make sure I get the timing perfect Thanks
Old Jan 28, 2006 | 02:20 PM
Johnv's Avatar
The dot on the snout is the zerrow advance/retard setting for keyway on crank, then just line up dot to dot on camshaft sprocket and outer dot near teeth on crankshaft sprocket
Old Jan 28, 2006 | 02:25 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Old Jan 28, 2006 | 02:34 PM
ashade98's Avatar
So just like Lithium has pictured? Thanks sooo much!
Old Jan 28, 2006 | 02:35 PM
Lithium's Avatar
That is if you are installing the cam dot to dot...What cam are you putting in?
Old Jan 28, 2006 | 02:39 PM
ashade98's Avatar
comp 224/224, .581, .581 on a 112!
