Head Install tips
Old Jan 31, 2006 | 05:13 PM
SSTYCOON's Avatar
Default Head Install tips
doing a head install soon. Any tips would be helpful, also any supplies that I could over look that I might need. I'm using ls1howto.com
thanks
Old Jan 31, 2006 | 05:17 PM
BBADWS6's Avatar
Remember the ground on the back of the drivers side head.
Old Jan 31, 2006 | 05:18 PM
Xtnct00WS6's Avatar
I'm going to be doing a head install soon too and one thing I'm going to try is hooking up a shop vac to the water pump so *maybe* I won't get a bunch of coolant in the bolt holes.
Old Jan 31, 2006 | 05:20 PM
WicketMike's Avatar
http://www.ls1howto.com/
Old Apr 4, 2006 | 12:07 AM
Azar's Avatar
LS1TECH Sponsor
I'm digging this one up, because "www.ls1howto.com" is the best site, EVAR...next to this site.
Old Apr 4, 2006 | 12:59 AM
BadBlackZ's Avatar
Ok i just read that whole page about the LS1 head swap. I think i will be trying this sometime soon. The only thing i dont really get is why they un-bolt the y-pipe? I mean the headers are still going to be there in the way so why take the trouble to unbolt them from the y-pipe?
Old Apr 4, 2006 | 08:49 AM
getlifted's Avatar
Bad Seller Alert
You will need to move the headers around to get to the bottom head bolts. So you need them to be lose.
Old Apr 4, 2006 | 09:09 AM
777's Avatar
777
Just know that you need a wrench to fit the power steering pump. Otherwise you will spend an hour trying to get that bolt off like I did. Also if possible take the headers off, or at least move them down a good it for clearance. Another thing that made everything difficult. Without those two problems I would have literally done it in half the time. And saved myself a lot of frustration. I mean A LOT!!
Old Oct 23, 2007 | 09:42 AM
Tram's Avatar
Yeh, the power steering pump is a PITA...
Old Oct 23, 2007 | 09:45 AM
}BlueFire{'s Avatar
I would say get a set of metric ratchet wrenches if you are gonna attempt a H/C install, not a mandatory item but deff. a time saver
Old Oct 23, 2007 | 10:05 AM
bowe1632's Avatar
Beer..
i like pabst blue ribbon, old time favorite...
no one should do these projects dry.
i believe there to be a bracket on the passenger side head..some of that **** was overcooking my grits so i left it off..just like ls1howto said...the hard part for me was breaking one of those bolts free back there...but, yeah remember bout those ground wires.
Old Oct 23, 2007 | 10:09 AM
Tram's Avatar
Getting the bolts off the back of the heads was not that bad for me..
I can't imagine how much of a PITA it's gonna be to get them back ON though..
Old Oct 23, 2007 | 10:19 AM
bowe1632's Avatar
not bad somehow, gettin em on wasn't too bad at all actually....i thought it was gonna be a pita too....well it felt like a bolt on one of the back of the stock heads for me was torqued to like 5 thousand foot pounds lol..i think my left arm is weak.
Old Oct 23, 2007 | 10:20 AM
Tram's Avatar
Was it the bolt on the back side of the PAX head? That joker was down pretty good..
