Head Flow Comparison Table
Old Feb 1, 2006 | 08:39 AM
No Juice's Avatar
Default Head Flow Comparison Table
I have compiled some head flow data over the past couple days and entered them in a spread sheet. Most of the data is Vendor posted and a few were independent tests. I don't remember which were independent.
I did my best to capture all the data but it was difficult to get all the info about each head and the test. So if you have some data to add or able to fill in my blanks feel free to send me a pm or just post up the info.
jrp - If you see this can you send me the link to your tests that you did? I coudn't find it for some reason.
http://i32.photobucket.com/albums/d8...ADFLOWDATA.jpg
edit--Updated table
Old Feb 1, 2006 | 09:32 AM
jub jub's Avatar
Thanks for posting! Do you think you could add stock LS1/6 heads for comparison?
Old Feb 1, 2006 | 09:52 AM
No Juice's Avatar
Sure but I don't have that data
Old Feb 1, 2006 | 10:27 AM
Felix C's Avatar
If you used Excell or similar to create the spreadsheet you can plot the different values on a graph. flow vs lift one for intake and one for exhaust. A good tool for calculating under the curve flow. .X50" nos. would be usefull in tightening up the curves.
Old Feb 1, 2006 | 10:31 AM
Felix C's Avatar
http://users3.ev1.net/~black_ops/heads/stockls1.jpg stock ls1
http://users3.ev1.net/~black_ops/heads/stockls6.jpg stock ls6
http://www.edelbrock.com/automotive_...61969_spec.pdf edelbrock
Old Feb 1, 2006 | 01:29 PM
Steve Jester's Avatar
Thanks for taking the time to gather and post all this info...Very informative!
Old Feb 1, 2006 | 01:43 PM
jub jub's Avatar
Thanks for that info. I didn't realize stock LS6 heads flowed so poorly.
Old Feb 1, 2006 | 01:57 PM
Greg Fell's Avatar
Throw the LS7's in it too. Richard @ WCCH just flowed a set...there is a post w numbers.
 Michael S. Palmer
Old Feb 1, 2006 | 02:50 PM
No Juice's Avatar
Thanks for the info fellas
I updated the table and will be adding LS7 info soon
Old Feb 1, 2006 | 06:09 PM
davered00ss's Avatar
Moderator
Great info. Thanks.
Old Feb 1, 2006 | 08:16 PM
jrp's Avatar
jrp
SN95 Director
here's a table of flow from circa ~03 that someone compiled back then. my head flow and PP head flow test data can be found in the FAQ linked in my sig. at any rate taken as a whole for comparitive purposes this data is worthless. and what you see isnt always what you get, i've been victim of the red pill twice, and its not a fun thing to swallow .
http://ourworld.cs.com/ls1info2/all+heads.jpg
Old Feb 5, 2006 | 08:44 AM
Moderator
I'm looking for heads now, and the more info I get the more confused i get.
Top choices:
1. AFR 205's
2. Patriot performance 243 castings
3. PRC (Texas Speed) ls6
4. PRC 5.3 liter heads?
