new lifters or not?
Old Feb 1, 2006 | 10:05 PM
BLUE99T/A's Avatar
Default new lifters or not?
I'm swapping heads and I can't decide whether to change the lifters or not. They have 90k on them. I know I'll eventually talk myself into changing them. With the cam swap I upgraded everything possible. Maybe what I'm asking is for someone to talk me out of it. What do you guys think?
Old Feb 1, 2006 | 10:51 PM
Greg Fell's Avatar
I would while you have the heads off. Try and get the Morels.
Old Feb 2, 2006 | 07:23 AM
Griswold's Avatar
I would definately change them since you have the heads off. Why risk one going bad after that many miles and damaging all your new parts.
Old Feb 2, 2006 | 08:41 PM
67Ranger's Avatar
yeah, they arent really that expensive, and they will be real hard to change if you wait too long. I just used a set of stock replacements, but they are new, and are workin great.
Old Feb 2, 2006 | 10:20 PM
DocEwww's Avatar
Definetly change them with the heads off.
Old Feb 3, 2006 | 11:11 AM
GuitsBoy's Avatar
Check out the melling lifter if your on a budget. If you can afford them, go with the morels.
Old Feb 4, 2006 | 12:13 PM
35thls1ss19's Avatar
not to hijack but should i change mine? they have 28k on them? thanks guys
heads and cam goin on are in my sig
Old Feb 4, 2006 | 09:14 PM
no one?
Old Feb 4, 2006 | 09:21 PM
cyphur's Avatar
i replaced my lifters when i got a new motor since the heads obviously would be off, went with GM 850-16s.
mellings are a good lifter too. almost went with them but found a better deal on the 850-16s, by good bit.
ArcticZ28's Avatar
No need to change the lifters unless it's a really high mileage engine, which might be a decent idea to play it safe (such as the 90k mile engine mentioned earlier). However, IF you are going to upgrade, just go with some Comp OE or GM replacements, and stay the hell away from the Comp R's unless you REALLY know what you're doing.
Old Feb 4, 2006 | 09:51 PM
mattsls1's Avatar
Look at my thread I just posted. Definately change your lifters lol.
Old Feb 4, 2006 | 10:31 PM
cowboysfan's Avatar
for insurance and peace of mind. change them!!! "enough said"
fuerzaws6
Old Feb 5, 2006 | 05:39 AM
DaleMX's Avatar
While you have the lifter carriage out increase the size of the oil retun hole a bit.
Old Feb 5, 2006 | 11:49 AM
99blancoSS's Avatar
Changed mine whe I did the heads at 75k. Good idea while your there, they're not that expensive.
Old Feb 5, 2006 | 12:13 PM
PREDATOR-Z's Avatar
Old Feb 5, 2006 | 12:15 PM
BlkHwk's Avatar
Why Morel? What advantage do they have over stock lifter?
They're pretty spendy, close to $500 the price I saw.
Old Feb 19, 2006 | 01:44 PM
AlohaC5's Avatar
What are the quality/reliability benefits of the Melling lifters over the OEM lifters - if any?
Old Feb 19, 2006 | 01:48 PM
GuitsBoy's Avatar
They look like a quality piece. Theyre the enclosed type, not the exposed roller type like the late model oem ones. That probably offers some structural rigidity.
Old Feb 19, 2006 | 02:08 PM
ShevrolayZ28's Avatar
I'll be replacing mine next time I have the heads off, and my car only has 35k on the clock. It's a lot of labor to get in there, and the parts are pretty cheap. It's worth it IMO.
Old Feb 19, 2006 | 03:32 PM
92zcamaroperson's Avatar
how do you go about doing that?
