rocker question
Old Jan 17, 2003 | 05:34 PM
dropped_ls1's Avatar
Default rocker question
i have a question about shaft mount rockers. if you use a shaft mount rocker can u still use stock valve covers with out any spacers. in other words will every thing still be in its stock location? thanks <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 17, 2003 | 08:59 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Default Re: rocker question
I have jessel non adjustable rockers i had to gut the inside of the valve covers to make them work. if you go with a t&d or a jessel adjustable you will need a spacer or a custom valve cover.i think cranes will fit with some mods to. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 18, 2003 | 01:42 AM
DONAIMIAN's Avatar
Depending on the year of the car you have you might either have to get new covers or just have a little grinding to do.
