hmmmm which one?...
Old Feb 3, 2006 | 05:10 AM
Transgression's Avatar
Question hmmmm which one?...
anybody had any luck with these?
FM-F6-114 FMS Custom Grind Camshaft - 226"/230" .575"/.595" 114LSA - semi-aggressive profile with a 2000-6800 RPM range, fair idle
and.......
FM-F7-114 FMS Custom Grind Camshaft - 224"/230" .588"/.595" 114LSA - aggressive profile with a 1800-6800 RPM range, fair idle, recommended for blower/nitrous applications
I'm thinking i might go with one of these insead of the TSP 228R.....how would one of those cams work with TSP's new LS6 ported cnc budget heads?
would u guys think one of those cams and the TSP LS6 heads make me happy power wise?(its gonna be in a true DD)Also see my sig for the other mods that will go on before the heads and cam)
Old Feb 4, 2006 | 07:48 AM
come on guys i need some opinions here!...please
Old Feb 4, 2006 | 04:59 PM
ok never freakin mind since no one wants to share there thoughts about the 2 cams i listed......later
Old Feb 4, 2006 | 05:11 PM
92CamaroReallySlow's Avatar
Well its not exactly an experience, but I kind of like the F6, and am thinking about going with it if I end up doing heads. I would also like to hear some feedback though...not only is the search cut off to a month, you cant search for just "F6" because its too short, so finding info that way is almost impossible right now.
Old Feb 4, 2006 | 09:27 PM
thanx man at least u said something kudos to u....and yeah I wanna know how it will like the PRC LS6 heads for my set up...unless i go with darts 225s
Old Feb 4, 2006 | 09:43 PM
redtail2426's Avatar
both cams would work great,but the f10 would work better,even in a DD.Its similar to the tsp 228,specs on the f10 are 228/228 576/576 112 or 114 for your automatic.Thats what im gonna use with the ported ls6 heads i have and i hear the f10 is not that bad to tune for.
Old Feb 5, 2006 | 09:52 AM
PREDATOR-Z's Avatar
TSP 228R is a good cam for your setup.
XE-R lobes, lifts within parameter of head output.
I say stick with your initial choice.
Old Feb 5, 2006 | 04:37 PM
k thanx man....i think i will!
but should i stick with either...(a. Dart 205cc heads (b. Dart 225cc heads or (c. tsp's new PRC stage 1 cnc ported LS6 heads
whick one of those heads would u guys chose for the future mods in my sig?!
thanx guys and Predator-Z!
Old Feb 6, 2006 | 01:33 AM
Old Feb 6, 2006 | 05:51 AM
PREDATOR-Z's Avatar
Either, LS2/LS6 stage 2 castings (243)
or
DART 205 cast
For the cam 228R,
For that cam I would pick the LS2 casting since they are cheap, and unmilled will accept a huge cam when you change your mind in , well.... 3months time
