Engine starter bump switch wiring
Phil
** Caution, with the spark plugs out the engine will spin over with no real load on the crankshaft. The cam bearings are fully loaded with valve spring pressure, they won't last long with no oil pressure. It takes over 30 seconds cranking the starter to get oil pressure to the cam or crank.
