LS1 water pumps with bolt-on pullies
Old Feb 4, 2006 | 11:34 AM
LS1PARTSGUY's Avatar
Default LS1 water pumps with bolt-on pullies
Does anyone know where I can buy some LS1 water pumps,preferably new,with the flange for a bolt-on pulley?
Old Feb 4, 2006 | 12:42 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default coolant pumps
Evans Cooling has high flow bolt on pulley pumps.
www.evanscooling.com
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Feb 4, 2006 | 05:57 PM
Thanks for the heads up.That is quite a pricy piece.
Old Feb 4, 2006 | 06:15 PM
cyphur's Avatar
**** yes it is
Old Feb 4, 2006 | 10:43 PM
LS1TECH Sponsor
Default Evans pumps
Evans stuff is not cheap by any means. Their product are very well designed.
I had some pump testing done a couple of years ago when designing the coolant holes in the MID sleeves. What we found was the stock LS1, LS6 pump lost almost half the flow to the right bank over 5,000 rpm. The Evans pump has almost equal flow. Also flows a lot more than the stock pump due to it's better impeller and slightly smaller pulley diameter to increase pump speed.
Bearings and shaft on the Evans are premium quality. They are expensive but you get what you pay for.
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
